It is currently May 14th, 2025, 12:14 am
PostPosted: November 5th, 2014, 5:32 pm
The original clock weaather widget from the ZTE Blade III.
Click on:
- The "arrows" button to Update weather
- The "View weather website" to open the Accuweather.com webpage.
The little ladybug shows the Battery level!
NOTE:
** FOR THE ANDROID VERSION PLEASE DOWNLOAD/USE THE WIDGET FROM THE OFFICIAL XW APPLICATION GALLLERY **
6/11/2014
FIX: I fixed some bad tags/codes.
PLEASE DOWNLOAD AGAIN!!!
zte_blade_3_clock_weather_hd.xwp [4.88 MiB]
Downloaded 296 times
PostPosted: November 5th, 2014, 7:30 pm
thanks bro for the quick reply........great work
PostPosted: November 6th, 2014, 2:05 am
You're welcome :)
PostPosted: November 6th, 2014, 3:31 am
PostPosted: November 6th, 2014, 3:46 am
thanks bro
Users browsing this forum: No registered users and 43 guests
