It is currently May 13th, 2025, 11:30 pm
 Post subject: Multi-Tab Glass Widget
PostPosted: September 12th, 2014, 11:45 am
An idea from a design by Freedom Design.
A high quality muti-tab widget in glass/transparent style!
CLICK ON THE BOTTOM BUTTONS TO NAVIGATE BETWEEN THE TABS
** TIME/DATE **
** CALENDAR **
- Click on the buttons to go to next/prev months.
- The upper image will change according the month.
** WEATHER **
- The upper image will change according the weather conditions.
** MUSIC PLAYER **
- Click on the buttons for Add Song, Edit tags, Search Cover, Shuffle, Repeat.
** SYSTEM INFORMATION **
- Click on the bottom buttons to Shutdown, Restart, Sleep the system.
-TimeZone Settings
-Go Today
-Update Weather
-Weather Details
-Change Location
-Change temp unit
-Music Player Settings
-Close Player
-Stop Player
-Shortcut Settings (appears only with mouse over the shortcut's name)
multi-tab_glass_widget.xwp [8.29 MiB]
Downloaded 240 times
Users browsing this forum: Bing [Bot] and 42 guests
