It is currently May 14th, 2025, 5:56 am
 Post subject: Prime Widgets
PostPosted: August 18th, 2014, 5:14 pm
An idea from a design by ZT.art
Includes 3 widgets:
* Date/Time - Battery
* Weather
* Music Player
**PRIME TIME:
**PRIME WEATHER:
**PRIME PLAYER:
- Add Song
- Search Cover Tool
- Edit Music Tags
- Player Settings
- Stop/Close Player
Use the mouse wheel on the roundline (over the cover) to control the player's volume.
Prime Widgets.zip [510.49 KiB]
Downloaded 145 times
 Post subject: Re: Prime Widgets
PostPosted: August 19th, 2014, 12:39 pm
how to use this?
PostPosted: August 19th, 2014, 2:16 pm
Download last version of Xwidget, download the. zip and double click on the file/s (. xwp) inside.
PostPosted: August 20th, 2014, 2:22 pm
can you tell me how can i change the name of the days? I wanto to translate to portuguese!
PostPosted: August 20th, 2014, 2:32 pm
Click on the corrisponding component on the left, open the "binding core" sub-tab on the right and delete the "En" from the tag.
From "${WeekEn}" to "${Week}".
This is also for all the tags that have the "En" inside.
PostPosted: August 20th, 2014, 2:36 pm
thanks
Users browsing this forum: Bing [Bot], Google [Bot] and 56 guests
