It is currently May 14th, 2025, 6:07 pm
 Post subject: Systemic Widget
PostPosted: April 10th, 2014, 8:54 am
Digital highly informative widget that shows:
* Computer/system informations
* Date/time
* Cpu, Ram, Swap, Hdd
* Internet
* Battery
* Recycle Bin
* Weather
- Open RB
- Clean RB
- Select BATTERY or RECYCLE BIN panel
Using the "Recycle Bin Panel" ON:
DOUBLE CLICK on the trash icon to "clean". (supports drag-drop function)
UPDATE:11/4/14
Fixed the bug of the XWidget and the battery lifetime tag/code.
Special thanks to hamid
systemic_widget.xwp [284.32 KiB]
Downloaded 174 times
 Post subject: Re: Systemic Widget
PostPosted: April 10th, 2014, 1:17 pm
jimking wrote:
NOTE:
There is a bug of XWidget with the battery lifetime display. To make it work properly you need to change the tag manually
from "${LifeTime}" to "%LifeTime"
you can add it to script code to automatically do the changes and prevent this problem from happening
PostPosted: April 10th, 2014, 3:48 pm
I didn't know hamid.. If you can help me, it will be great! Thanks :)
PostPosted: April 11th, 2014, 6:11 am
i don't have battery to test it, but it should work correctly
systemic_widget [test1] [2014.04.11].xwp [284.32 KiB]
Downloaded 141 times
PostPosted: April 11th, 2014, 8:18 am
Yes works fine! Thanks hamid! :D
Original file updated..
Users browsing this forum: Bing [Bot] and 83 guests
