It is currently May 14th, 2025, 6:08 pm
 Post subject: Antique Widgets
PostPosted: January 14th, 2014, 3:08 pm
Original design by Randomwork. (mod by me)
Includes 5 widgets:
- CPU
- RAM
- SWAP
- BATTERY
- HDD (right for select the drive)
- VOLUME (Use the "-" or "+" to control the volume.)
To add multiple HD widgets:
Then right click on the 2nd, 3rd.... widget a click select drive.
You can find the "Antique Battery Widget" here:
viewtopic.php?f=11&t=3977
Antique Widgets.zip [6.95 MiB]
Downloaded 109 times
Users browsing this forum: Bing [Bot] and 84 guests
