A PS3 as Music Player for your desktop!
...with animation for the Blu-ray Disc:
Press PLAY / STOP and see the disc slide In/Out like the real one!
The "Volume" text percentage appears when you put the mouse over the volume buttons/controls.
NOTES:Add the buttons have the "Hint" option enable so it's easy to find all the functions...
You can use the resize / rotate XWidget's options if you want to decrease the size or rotate the widget.
...and remember: don't take life too seriously...My profile on Deviantart:
http://jimking.deviantart.com/
