It is currently May 14th, 2025, 5:16 am
 Post subject: Elegant Meters
PostPosted: October 28th, 2013, 3:19 am
Includes 6 widgets:
- HDD
(right click for select disk. To add multiple HD widgets:
Then right click on the 2nd, 3rd.... widget a click select drive).
- CPU
- RAM
- SWAP
- BATTERY
- VOLUME
(click on "-" / "+" or use the mouse wheel to control the volume)
Elegant Meters.zip [637.32 KiB]
Downloaded 260 times
Users browsing this forum: No registered users and 46 guests
