It is currently May 14th, 2025, 6:20 am
 Post subject: Milky Meters Dark
PostPosted: October 24th, 2013, 10:15 am
This is the Dark version of the "Milky Meter Widgets" pack.
Includes 6 widgets:
- CPU
- RAM
- SWAP
- BATTERY
- HDD (right for select the drive)
- VOLUME
To add multiple HD widgets:
Then right click on the 2nd, 3rd.... widget a click select drive.
UPDATED: Added "VOLUME" meter. Use the "-" or "+" to control the volume.
Milky Meters Dark.zip [641.81 KiB]
Downloaded 163 times
Users browsing this forum: Google [Bot] and 69 guests
