It is currently May 14th, 2025, 6:39 am
 Post subject: Battery HD Widget
PostPosted: October 15th, 2013, 12:31 pm
Check the battery level with this HD widget..!
Includes two versions: Horizontal and Vertical battery.
Click on to show/hide the percentage.
Battery HD Widget.zip [227.34 KiB]
Downloaded 252 times
 Post subject: Re: Battery HD Widget
PostPosted: October 16th, 2013, 2:13 am
UPDATE 16/10/13:
Fixed the "click on" function on Vertical widget.
Users browsing this forum: Bing [Bot] and 56 guests
