It is currently May 14th, 2025, 5:18 am
 Post subject: Taskbar [UPDATED]
PostPosted: August 18th, 2013, 1:25 am
Just a simple AIO bar with nice animations 8-)
I'm not gonna write any instructions here 'cause every clickable thing on the widget has an explanatory tooltip
P.S.: the GMail icon is only B/W when the inbox is empty :D
P.P.S.: the widget is 1500 pixels wide so it only looks good on a full HD resolution (sorry :( ) ... you can still use it on a smaller resolution though if you scale it down
Update log:
v1.0.1
- Shaking GMail icon (only when you have mail)
- progress bar in music section (a cool glass one :))
- font changed to Arial, Arial Rounded Bold and Arial Black
- auto position-locking
v1.0.2
- progress bar for seconds [Clock section]
- elastic effect for animations
- volume bar [Music section]
v1.0.3
- ability to toggle sections
Any suggestions for the next update?
enjoy :!:
File comment: widget v1.0.3
taskbar.XWidgetPkg [700.29 KiB]
Downloaded 200 times
File comment: ScreenShot
..:: LCi™ ::..
 Post subject: Re: Taskbar
PostPosted: August 18th, 2013, 2:33 am
Really cool! 8-)
Thanks for sharing!
PostPosted: August 18th, 2013, 2:47 am
jimking wrote:
Really cool! 8-)
Thanks for sharing!
Thanks! I'm glad you like it :)
..:: LCi™ ::..
PostPosted: August 18th, 2013, 3:07 am
jimking wrote:
Really cool! 8-)
Thanks for sharing!
check out the "new" version :)
..:: LCi™ ::..
PostPosted: August 18th, 2013, 9:59 am
Nice! & Many thanks for demonstrating how to replace Tues/Thur by Tue/Thu! :)
PostPosted: August 18th, 2013, 10:15 am
You're very welcome :D
..:: LCi™ ::..
Users browsing this forum: No registered users and 45 guests
