It is currently May 14th, 2025, 6:05 am
PostPosted: July 5th, 2013, 11:25 am
This a MULTI-Photo Album widget! :D
Why?
It uses 5 photoalbumcores (one for every image) instead of 1 general core as usual. This means that you can setup independently each frame, so you can have a slideshow from 5 different folders! But even when you use the same folder for all frames, the images are shown randomly, so are all different! ;)
Right click on each frame to edit/change the Album settings.
Click on each frame to go to the next image.
filmstrip_multi-photo_album.zip [2.08 MiB]
Downloaded 221 times
PostPosted: July 23rd, 2013, 1:58 pm
This is great idea. Love it and use it!
PostPosted: July 23rd, 2013, 2:02 pm
Thanks! ;)
Users browsing this forum: Bing [Bot], Google [Bot] and 62 guests
