It is currently May 13th, 2025, 11:42 pm
PostPosted: May 30th, 2013, 3:26 am
Original idea and design by "Long" and "Glass Sliding Door"
http://bbs.ku-yu.com/forum.php?mod=view ... a=page%3D1
The original widget did not work, so I edited all its components, added some codes, and here is my mod working version.
HOW WORKS:
Add this widget as the last one on your desktop. For not having problem with the appearing of the other widgets, just position the rest of them on the "Bottom": Window->Position->Bottom
(The HandPoint cursor will appear)
Press on the middle (handles) to open the sliding door.
Press on the middle right or left of the window to close it.
Is resized to 1366 x 768 resolution to fit with my laptop's resolution.
IF YOU WANT A LARGER VERSION FOR HIGHER RESOLUTION SCREEN, ADD YOUR COMMENT BELOW AND I'LL TRY TO POST IT!! ;)
glass_sliding_door_mod.zip [1.7 MiB]
Downloaded 163 times
Users browsing this forum: No registered users and 37 guests
