It is currently May 13th, 2025, 5:57 pm
 Post subject: Wanted Widget (Far West)
PostPosted: May 23rd, 2013, 6:26 am
A special widget for your desktop, Far West style!
Add your photo in the frame and don't forget:
MORE TIME YOU SPEND AT YOUR PC, MORE WANTED AND PRECIOUS YOU WILL BE...!!! :D
Shows:
- Your city's name
- The user name of your pc
- The date
- OS uptime (hours - minutes)
- Photo Settings
- Search City
FOR ADD AND SHOW A SINGLE IMAGE AS I DID HERE IS THIS SIMPLE TRICK:
Create a folder in your pc (any place) and add only the picture that the widget will use.
Right click on the widget, select "Photo settings" and select the folder that you created.
So with only one picture in folder, there is no any "slideshow" and the widget will show only this pic.
That's all! ;)
wanted_widget.zip [1.42 MiB]
Downloaded 158 times
Users browsing this forum: Bing [Bot], Google [Bot] and 42 guests
