It is currently May 13th, 2025, 6:37 pm
PostPosted: May 16th, 2013, 6:14 pm
Original design by Microsys
http://www.microsys.ro/
Special thanks to Cov that provide me the .png files and help me with his suggestions and tests! :)
Includes 7 Gauge Widgets:
CPU
RAM
HDD
SWAP
DOWNLOAD
UPLOAD
BATTERY
On HDD widget right click for select the drive.
To add multiple HD widgets:
Then right click on the 2nd, 3rd.... widget a click select drive.
UPDATE:
Now with 3 different backgrounds:
Grey (default)
Dark
Light
selectable for ALL Gauges! :D
Mini Gauge Widgets.zip [702.31 KiB]
Downloaded 175 times
PostPosted: May 17th, 2013, 3:05 am
Grey (default)
Dark
Light
Users browsing this forum: Google [Bot] and 42 guests
