It is currently May 14th, 2025, 5:26 am
PostPosted: May 3rd, 2013, 5:09 am
Special thanks to digigamer who helped me making the offline code for the moon phase.
Shows:
- City's name, wind direction, current temp
- Current weather conditions
- Today weather condition with image
- High/Low temp
- Moon phase info/time
- Moonrise/Moonset time
- Search City
Click on "More Info" to connect to "iohelix.net" for more details. (thanks to qiancang)
moon_phase_weather_widget.zip [4.74 MiB]
Downloaded 279 times
PostPosted: September 3rd, 2014, 6:44 pm
Hi, I'm not sure if the moon phase is calculated for the southern hemisphere.
the image just needs to be flipped 180 deg.
What I did was to go to the phases image folder and rotated all images 180 degrees. (quick fix)
moon.Src = 'Phases\\' + hemisphere + age +'.png';
Southern Hemisphere
Imagehttps://www.youtube.com/watch?v=Jt0-tbcC0fA
Northern Hemisphere
Imagehttps://www.youtube.com/watch?v=7vUObZwLJ8A
PostPosted: September 4th, 2014, 12:04 am
Jimking correct picture in the first post.
PostPosted: September 4th, 2014, 6:03 am
Was a temp issue of the site where I had uploaded the pic. As you can see is back online.
