It is currently May 14th, 2025, 12:07 am
 Post subject: Advanced Info Tabs
PostPosted: April 22nd, 2013, 9:19 am
(an idea from khaki trends by mbgd-d4logml)
-Search City
Refresh the weather using the top-right icon.
advanced_info_tabs.zip [599.65 KiB]
Downloaded 227 times
 Post subject: Re: Advanced Info Tabs
PostPosted: April 29th, 2013, 8:47 pm
Awesome!
Three questions please:
1. can the clock be set to 24h system?
2. can displays for additional storages be added (HDD 2, HDD 3, etc)?
3. can the modules be used one by one or do we have to use all at once?
Thank you
PostPosted: April 30th, 2013, 11:52 pm
Thanks Cov!
1. Right click->edit. Select "Menus" on the left, press "+"(add menu item)
Now on the right, in "Caption" write 12h/24h, "Binding Code" select Datetimecore1, "On Click" select !12h/24h.
Exit->save
2. The design is for one HDD
3. The background image includes all the tabs,so can be used only like this
PostPosted: May 1st, 2013, 7:47 am
Hi jimking,
1 - I right click the widget and select edit
2 - I select Menu on the left
3 - I rightclick within the window and select "Add MenuItem"
4 - I write "12h/24h" on the right under "caption"
5 - I select "Datetimecore1" on the right under "Binding Code"
6 - but I can't find "on click" ... where is it?
Oh, I see. What a pitty.
PostPosted: May 1st, 2013, 7:51 am
Cov wrote:
Hi jimking,
The "on click" menu is just under the Binding Code (always in "Menu")!
PostPosted: May 1st, 2013, 8:11 am
It's working now, thank you!
PostPosted: May 29th, 2013, 7:04 pm
thank you very much.....
Bayern Munich, nuevo rey del camisetas fĂștbol baratas europeo
Users browsing this forum: No registered users and 39 guests
