It is currently May 13th, 2025, 5:35 pm
 Post subject: Time Convertor
PostPosted: April 13th, 2013, 1:30 am
Enter time in [hour]-[minute]-[second] format and see
how many seconds is that, or do it opposite, put your
seconds and see what is it in [hour]-[minute]-[second]
I made it because windows shutdown command
take time in seconds, for example if I want turn
my computer off in next 2 hours and 45 minutes,
I need to know how many seconds is that time
I hope you find this widget useful too
... and, how can I put my widgets on XWidgets gallery?
time_convertor.XWidgetPkg [33.32 KiB]
Downloaded 291 times
 Post subject: Re: Time Convertor
PostPosted: April 13th, 2013, 3:22 am
Tony decides and puts them in the official gallery.. ;)
PostPosted: April 13th, 2013, 4:00 am
Good job! It is useful , thanks :)
PostPosted: April 13th, 2013, 4:28 am
This is a very good idea!
I love this useful widgets!!!
Thanks for sharing!
PostPosted: April 14th, 2013, 2:54 am
Thanks guys, all of you (jimking, Tony, Armando).
I love XWidget its beauty and it use less memory than Windows 7 gadgets
I just cant wait for finding some idea to do it with XWidget
PostPosted: May 4th, 2013, 12:53 am
Thanks for sharing!
runescape gold|Rs gold|buy runescape gold|Cheap runescape gold
PostPosted: May 4th, 2013, 12:47 pm
It would be good if we had a list of ideas :idea: in a separate section
People could create widgets starting with these ideas :)
It would be interesting to see how different people tackle the task.
PostPosted: May 4th, 2013, 7:31 pm
Good idea meme!
Users browsing this forum: No registered users and 48 guests
