It is currently May 14th, 2025, 11:25 am
PostPosted: January 12th, 2013, 3:38 am
Video:
View on Youtube: http://www.youtube.com/watch?v=EVDLFTmBn6M
Download: http://www.xwidget.com/xwidget/widgets/ ... 2/377.html
TSF Weather for xwidget port by WuJie
Click the background to Expand/Collapse
Right click to change location and Enabled/Disabled Shake
PostPosted: December 26th, 2013, 11:17 am
Just curious has anyone gotten this one to work properly on an android phone? Thanks.
PostPosted: December 26th, 2013, 12:44 pm
The Android version of XWidget doesn't support (yet?) the script codes..
PostPosted: December 26th, 2013, 7:04 pm
jimking do you know it will support javascript code someday :?:
PostPosted: December 26th, 2013, 7:44 pm
Thanks for the reply.
Users browsing this forum: Bing [Bot], Google [Bot] and 43 guests
